Ga door naar hoofdinhoud
Sony Vaio Tap 11 Power Jack Replacement
Wat je nodig hebt
  1. Sony Vaio Tap 11 Power Jack Replacement, Screen Assembly: stap 1, afbeelding 1 van 1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Power Jack Replacement: stap 2, afbeelding 1 van 1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Power Jack Replacement: stap 3, afbeelding 1 van 2 Sony Vaio Tap 11 Power Jack Replacement: stap 3, afbeelding 2 van 2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Power Jack Replacement, Battery: stap 4, afbeelding 1 van 1
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Power Jack Replacement: stap 5, afbeelding 1 van 1
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Power Jack Replacement, Power Jack: stap 6, afbeelding 1 van 1
    • Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
  7. Sony Vaio Tap 11 Power Jack Replacement: stap 7, afbeelding 1 van 1
    • Unplug the jack from the motherboard.
  8. Sony Vaio Tap 11 Power Jack Replacement: stap 8, afbeelding 1 van 1
    • Remove the metal covering.
  9. Sony Vaio Tap 11 Power Jack Replacement: stap 9, afbeelding 1 van 1
    • Pull out the cable and jack assembly.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Alexander Bridges
1.217 Reputatie
7 handleidingen geschreven
IUPUI, Team 1-2, Harley Fall 2015 Lid van IUPUI, Team 1-2, Harley Fall 2015
IUPUI-HARLEY-F15S1G2
4 Leden
20 handleidingen geschreven
2 opmerkingen
I wonder if you have the part number or can supply this power jack?
James Toal - Antwoord
Yes, Where can I find this replacement part?
mikebeard65 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 18
Altijd: 1,775
