Inleiding
SSDs are a way to quickly store and access saved data on your computer
Wat je nodig hebt
Flip the laptop over so that the battery on the underside of the device is revealed.
Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
Unscrew the three 4mm screws using a JIS #0 screwdriver.
Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
Grab and lift the edge of the panel to pull it free from the rest of the computer.
Unscrew single 4mm screw using a JIS #0 screwdriver.
Lift up one end of the SSD.
Pull the SSD from its port.
