Ga door naar hoofdinhoud
Sony Vaio SVT151A11L Multimedia Card Replacement
Wat je nodig hebt
  1. Sony Vaio SVT151A11L Multimedia Card Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Vaio SVT151A11L Multimedia Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Multimedia Card Replacement: stap 2, afbeelding 1 van 3 Sony Vaio SVT151A11L Multimedia Card Replacement: stap 2, afbeelding 2 van 3 Sony Vaio SVT151A11L Multimedia Card Replacement: stap 2, afbeelding 3 van 3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L Multimedia Card Replacement, Back Panel: stap 3, afbeelding 1 van 3 Sony Vaio SVT151A11L Multimedia Card Replacement, Back Panel: stap 3, afbeelding 2 van 3 Sony Vaio SVT151A11L Multimedia Card Replacement, Back Panel: stap 3, afbeelding 3 van 3
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L Multimedia Card Replacement: stap 4, afbeelding 1 van 3 Sony Vaio SVT151A11L Multimedia Card Replacement: stap 4, afbeelding 2 van 3 Sony Vaio SVT151A11L Multimedia Card Replacement: stap 4, afbeelding 3 van 3
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
  5. Sony Vaio SVT151A11L Multimedia Card Replacement, Multimedia Card: stap 5, afbeelding 1 van 1
    • Get unobstructed access to the multimedia card.
  6. Sony Vaio SVT151A11L Multimedia Card Replacement: stap 6, afbeelding 1 van 2 Sony Vaio SVT151A11L Multimedia Card Replacement: stap 6, afbeelding 2 van 2
    • Unscrew the two 2mm screws from the board using JIS #0 screwdriver.
  7. Sony Vaio SVT151A11L Multimedia Card Replacement: stap 7, afbeelding 1 van 2 Sony Vaio SVT151A11L Multimedia Card Replacement: stap 7, afbeelding 2 van 2
    • Lift up multimedia card.
    • Pull out ribbon cable from connected board.
Conclusie
Namuundari Zorigtbaatar
201 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S4-G6, Julie Fall 2017 Lid van UMass Dartmouth, Team S4-G6, Julie Fall 2017
UMASSD-JULIE-F17S4G6
2 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 17
Altijd: 652
