Inleiding
The Hard Drive replacement is a fairly simple process. Allocate about 30 minutes for this replacement, making sure to take your time and keep your screws organized.
It's also important to note that in addition to the high-capacity hard drive that we cover in this guide, there is a small NVMe solid state drive which is commonly used as a boot-device for this series of laptop. If you complete this replacement and your computer is still exhibiting the same issues, check the status of the SSD as well.
Wat je nodig hebt
Carefully grab the edges of the laptop and flip it over to reveal the back panel.
The battery is located on the lower half of the back panel, and contains three 10mm flat-head screws.
Unscrew the three 10mm flat-head screws using a flat-head screw driver.
Lift the battery from the lip closest to the middle screw to remove the battery entirely.
The middle Phillips head screw is 10mm in length and will only fit in this thread. Unscrew the 10mm Phillips head screw and keep it separate from the other two screws in this step.
Unscrew the two remaining 5mm Phillips head screws on the left and right side of the hard drive bay cover.
Lift the panel to remove it.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
I would like to know if you sell the adapter for the hard drive because I have this laptop and all I need is the hard drive adapter to connect a hard drive if you could email me at stephenwrayexley@gmail.com I would greatly appreciate that
bom dia, tem algum video mostrando como instalar o widnows 10 nesse vaio sendo que o mesmo esta com W7? Não consegui entender a BIOS com RAID etc. grato
