Ga door naar hoofdinhoud
Sony Vaio SVF15A16CXB Back Panel Replacement
Wat je nodig hebt
  1. Sony Vaio SVF15A16CXB Back Panel  Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Back Panel  Replacement: stap 2, afbeelding 1 van 2 Sony Vaio SVF15A16CXB Back Panel  Replacement: stap 2, afbeelding 2 van 2
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Back Panel  Replacement: stap 3, afbeelding 1 van 1
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Back Panel  Replacement: stap 4, afbeelding 1 van 1
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 999
