Ga door naar hoofdinhoud
Sony Vaio SVE171C11L Motherboard Replacement
Wat je nodig hebt
  1. Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Sony Vaio SVE171C11L Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Turn the laptop facedown.
    • Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
    • Push the two tabs up to release the battery. Set it aside.
  2. Sony Vaio SVE171C11L Motherboard Replacement: stap 2, afbeelding 1 van 2 Sony Vaio SVE171C11L Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Rotate the laptop so the empty battery compartment is now at the bottom.
    • Remove the two screws that secure the hard drive cover using a T5 Torx screwdriver. Set it aside.
  3. Sony Vaio SVE171C11L Motherboard Replacement: stap 3, afbeelding 1 van 2 Sony Vaio SVE171C11L Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the three screws securing the hard drive disk in place.
    • Use the blue ribbon attached to the hard drive disk to carefully remove it from laptop. Set it aside.
  4. Sony Vaio SVE171C11L Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove all screws holding the back panel from the laptop.
    • Carefully pull up the back panel to remove it.
  5. Sony Vaio SVE171C11L Motherboard Replacement: stap 5, afbeelding 1 van 3 Sony Vaio SVE171C11L Motherboard Replacement: stap 5, afbeelding 2 van 3 Sony Vaio SVE171C11L Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Remove the cables from the fan and unscrew the heatsink.
    • The heatsink has many metal pieces jutting out from its base and is located under the fan.
    • Carefully disconnect the tabs on the edges of the motherboard.
    • Unscrew the screws holding the motherboard in place. Set them aside.
    • On the underside of the motherboard, disconnect the keyboard from the motherboard.
    • Once ALL cables are disconnected, carefully remove the motherboard.
Conclusie
Edward Briseno
893 Reputatie
6 handleidingen geschreven
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Lid van CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 324
