Ga door naar hoofdinhoud
Sony Vaio SVE171C11L Display Replacement
Wat je nodig hebt
  1. Sony Vaio SVE171C11L Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L Display Replacement: stap 2, afbeelding 1 van 1
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L Display Replacement: stap 3, afbeelding 1 van 1
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L Display Replacement: stap 4, afbeelding 1 van 1
    • Pull the battery away.
  5. Sony Vaio SVE171C11L Display Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the two screws that secure the hard drive cover.
  6. Sony Vaio SVE171C11L Display Replacement: stap 6, afbeelding 1 van 2 Sony Vaio SVE171C11L Display Replacement: stap 6, afbeelding 2 van 2
    • After the screw have been removed, pop the hard drive cover open.
  7. Sony Vaio SVE171C11L Display Replacement: stap 7, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 3 screws that secure the hard drive.
  8. Sony Vaio SVE171C11L Display Replacement: stap 8, afbeelding 1 van 1
    • When finished removing the screws, use your fingers to hold the blue ribbon attached from the hard drive to remove it from laptop
  9. Sony Vaio SVE171C11L Display Replacement, Display: stap 9, afbeelding 1 van 1
    • There are two hinges that connect the display to the body of the laptop
    • Unscrew two 9mm screws and two 4mm screws that are on both hinges.
  10. Sony Vaio SVE171C11L Display Replacement: stap 10, afbeelding 1 van 1
    • Remove the display cable by pulling upward.
  11. Sony Vaio SVE171C11L Display Replacement: stap 11, afbeelding 1 van 1
    • Remove the display from the bottom of the laptop.
  12. Sony Vaio SVE171C11L Display Replacement: stap 12, afbeelding 1 van 2 Sony Vaio SVE171C11L Display Replacement: stap 12, afbeelding 2 van 2
    • Remove the four 5mm screws on the corners of the display case.
  13. Sony Vaio SVE171C11L Display Replacement: stap 13, afbeelding 1 van 1
    • Use the pick around the case to help detach them.
  14. Sony Vaio SVE171C11L Display Replacement: stap 14, afbeelding 1 van 2 Sony Vaio SVE171C11L Display Replacement: stap 14, afbeelding 2 van 2
    • Remove the three 2mm screws that are on each hinge.
  15. Sony Vaio SVE171C11L Display Replacement: stap 15, afbeelding 1 van 1
    • Remove the display from its case.
Conclusie
Edward Briseno
896 Reputatie
6 handleidingen geschreven
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Lid van CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 248
