Ga door naar hoofdinhoud
Sony Vaio SVE171C11L Battery Replacement
Wat je nodig hebt
  1. Sony Vaio SVE171C11L Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop over so its underside is facing upwards and visible.
  2. Sony Vaio SVE171C11L Battery Replacement: stap 2, afbeelding 1 van 1
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
  3. Sony Vaio SVE171C11L Battery Replacement: stap 3, afbeelding 1 van 1
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
  4. Sony Vaio SVE171C11L Battery Replacement: stap 4, afbeelding 1 van 1
    • Pull the battery away.
Conclusie
Edward Briseno
896 Reputatie
6 handleidingen geschreven
CSU Los Angeles, Team 6-3, Adachi Fall 2022 Lid van CSU Los Angeles, Team 6-3, Adachi Fall 2022
CSULA-ADACHI-F22S6G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 217
