Ga door naar hoofdinhoud
Sony Vaio SVE15112FXS LCD Screen Replacement
Wat je nodig hebt
  1. Sony Vaio SVE15112FXS LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS LCD Screen Replacement: stap 2, afbeelding 1 van 3 Sony Vaio SVE15112FXS LCD Screen Replacement: stap 2, afbeelding 2 van 3 Sony Vaio SVE15112FXS LCD Screen Replacement: stap 2, afbeelding 3 van 3
    • Slide the "lock" tab upward to unlock the battery before removal.
    • While pushing the "release" tab upward, lift the battery and pull outward to remove it from the laptop.
  3. Sony Vaio SVE15112FXS LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Turn the computer back over and open the lid.
    • Remove the four rubber screw covers at each corner of the screen to expose the bezel screws
  4. Sony Vaio SVE15112FXS LCD Screen Replacement: stap 4, afbeelding 1 van 1
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screen bezel screws in each corner.
  5. Sony Vaio SVE15112FXS LCD Screen Replacement: stap 5, afbeelding 1 van 2 Sony Vaio SVE15112FXS LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Insert a plastic opening tool between the bezel and laptop lid. Work it around the edge to loosen the bezel.
    • Lift the bezel outward to remove it and expose the screen.
    • Take care when using the spudger near the hinges to avoid breaking the bezel.
  6. Sony Vaio SVE15112FXS LCD Screen Replacement: stap 6, afbeelding 1 van 2 Sony Vaio SVE15112FXS LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Use a #0 Phillips screwdriver to remove the four 3.0 mm screen screws.
    • Cover the keyboard with a cloth or towel to protect the screen and keep any broken glass out of the keyboard.
  7. Sony Vaio SVE15112FXS LCD Screen Replacement: stap 7, afbeelding 1 van 3 Sony Vaio SVE15112FXS LCD Screen Replacement: stap 7, afbeelding 2 van 3 Sony Vaio SVE15112FXS LCD Screen Replacement: stap 7, afbeelding 3 van 3
    • Pull the screen toward you and away from the lid until a silver cable behind the screen is visible.
    • Remove the silver cable from the back of the screen. It is glued at the top and the bottom.
    • Do not pull the cable loose from the lid, only remove it from the back of the screen.
  8. Sony Vaio SVE15112FXS LCD Screen Replacement: stap 8, afbeelding 1 van 3 Sony Vaio SVE15112FXS LCD Screen Replacement: stap 8, afbeelding 2 van 3 Sony Vaio SVE15112FXS LCD Screen Replacement: stap 8, afbeelding 3 van 3
    • Lift the barcode label on the back of the screen upward to loosen the screen cable connector.
    • Once the connector is visible, remove it from the pins on the back of the screen.
  9. Sony Vaio SVE15112FXS LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Lift the screen toward you to remove it completely from the lid.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ashley Bierman
1.223 Reputatie
5 handleidingen geschreven
Ohio State, Team S1-G1, Whitney Fall 2018 Lid van Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 38
Altijd: 809
