Ga door naar hoofdinhoud
Sony Vaio SVE15112FXS Hard Drive Replacement
Wat je nodig hebt
  1. Sony Vaio SVE15112FXS Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Power laptop off before beginning.
    • Turn the laptop over so that it is positioned top down with the model number facing you.
  2. Sony Vaio SVE15112FXS Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws securing the hard drive cover.
    • To avoid losing any parts, we recommend that you place the loose screws on a magnetic project mat.
  3. Sony Vaio SVE15112FXS Hard Drive Replacement: stap 3, afbeelding 1 van 2 Sony Vaio SVE15112FXS Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • To expose the hard drive, remove the cover by sliding it toward you and pulling up on the panel.
  4. Sony Vaio SVE15112FXS Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Use a #0 Phillips screwdriver to remove the two 4.0 mm screws attaching the hard drive to the laptop.
  5. Sony Vaio SVE15112FXS Hard Drive Replacement: stap 5, afbeelding 1 van 2 Sony Vaio SVE15112FXS Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Pull the clear plastic ribbon to the left until the mount is detached from the laptop.
    • There will be some resistance as the hard drive is disconnected. If it does not move at all, check that all anchor screws are removed.
    • Lift the hard drive out of the well.
  6. Sony Vaio SVE15112FXS Hard Drive Replacement: stap 6, afbeelding 1 van 2 Sony Vaio SVE15112FXS Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Use a #0 Phillips screwdriver to remove the four 4.0 mm screws attaching the mount to the hard drive.
    • Slide the hard drive away from the mount until it is completely detached.
    • Take note of how the mount is positioned when attached to the hard drive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ashley Bierman
1.223 Reputatie
5 handleidingen geschreven
Ohio State, Team S1-G1, Whitney Fall 2018 Lid van Ohio State, Team S1-G1, Whitney Fall 2018
OSU-WHITNEY-F18S1G1
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 700
