Ga door naar hoofdinhoud
Sony Vaio SVE111B11L Motherboard Replacement
Wat je nodig hebt
  1. Sony Vaio SVE111B11L Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Vaio SVE111B11L Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Motherboard Replacement, Keyboard Assembly: stap 4, afbeelding 1 van 1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Motherboard Replacement: stap 7, afbeelding 1 van 3 Sony Vaio SVE111B11L Motherboard Replacement: stap 7, afbeelding 2 van 3 Sony Vaio SVE111B11L Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
  8. Sony Vaio SVE111B11L Motherboard Replacement, Fan: stap 8, afbeelding 1 van 1
    • Locate the fan and heat-sink.
  9. Sony Vaio SVE111B11L Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Locate the wires and connectors, and gently unplug them.
  10. Sony Vaio SVE111B11L Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Locate and remove the 6.7 mm screws that hold the fan assembly.
  11. Sony Vaio SVE111B11L Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Gently lift the fan assembly up and out.
  12. Sony Vaio SVE111B11L Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 1
    • Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Take the covers on the bottom of the laptop off.
  13. Sony Vaio SVE111B11L Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  14. Sony Vaio SVE111B11L Motherboard Replacement: stap 14, afbeelding 1 van 3 Sony Vaio SVE111B11L Motherboard Replacement: stap 14, afbeelding 2 van 3 Sony Vaio SVE111B11L Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Locate the wires and connectors and remove them from the motherboard.
  15. Sony Vaio SVE111B11L Motherboard Replacement: stap 15, afbeelding 1 van 2 Sony Vaio SVE111B11L Motherboard Replacement: stap 15, afbeelding 2 van 2
    • Lift the mother board out and safely put it to the side.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Noll
819 Reputatie
5 handleidingen geschreven
Één opmerking
i have the same laptop, and i mistakenly remove the mother board cmos battery , and is not recognizing my laptop system hard drive.
in this case what can i do in other to restore it back.
onyebuchiadieze - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 1,917
