Ga door naar hoofdinhoud
Sony Vaio SVE111B11L Keyboard Assembly Replacement
Wat je nodig hebt
  1. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Vaio SVE111B11L Keyboard Assembly Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L Keyboard Assembly Replacement: stap 2, afbeelding 1 van 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L Keyboard Assembly Replacement: stap 3, afbeelding 1 van 1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L Keyboard Assembly Replacement, Keyboard Assembly: stap 4, afbeelding 1 van 1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L Keyboard Assembly Replacement: stap 5, afbeelding 1 van 1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L Keyboard Assembly Replacement: stap 6, afbeelding 1 van 1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L Keyboard Assembly Replacement: stap 7, afbeelding 1 van 3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: stap 7, afbeelding 2 van 3 Sony Vaio SVE111B11L Keyboard Assembly Replacement: stap 7, afbeelding 3 van 3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
Conclusie
John Noll
819 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,204
