Ga door naar hoofdinhoud
Sony Vaio PCG-F360 Optical Drive Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-F360 Optical Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Optical Drive Replacement: stap 4, afbeelding 1 van 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: stap 5, afbeelding 1 van 3 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: stap 5, afbeelding 2 van 3 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: stap 5, afbeelding 3 van 3
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 Optical Drive Replacement: stap 6, afbeelding 1 van 3 Sony Vaio PCG-F360 Optical Drive Replacement: stap 6, afbeelding 2 van 3 Sony Vaio PCG-F360 Optical Drive Replacement: stap 6, afbeelding 3 van 3
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 Optical Drive Replacement: stap 7, afbeelding 1 van 2 Sony Vaio PCG-F360 Optical Drive Replacement: stap 7, afbeelding 2 van 2
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
  8. Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: stap 8, afbeelding 1 van 2 Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: stap 8, afbeelding 2 van 2
    • Remove the three screws surrounding the fan.
    • Take off the guard that you just unscrewed.
    • Carefully flip over the heat pipe and the metal sheet connected to it.
  9. Sony Vaio PCG-F360 Optical Drive Replacement: stap 9, afbeelding 1 van 3 Sony Vaio PCG-F360 Optical Drive Replacement: stap 9, afbeelding 2 van 3 Sony Vaio PCG-F360 Optical Drive Replacement: stap 9, afbeelding 3 van 3
    • Remove the three screws from the heat tube cover.
    • Carefully remove the cover.
  10. Sony Vaio PCG-F360 Optical Drive Replacement: stap 10, afbeelding 1 van 2 Sony Vaio PCG-F360 Optical Drive Replacement: stap 10, afbeelding 2 van 2
    • Use a spudger to pry the ribbon connected to the optical drive.
    • Slide the optical drive free of the enclosure.
Conclusie
ahintz
28 Reputatie
8 handleidingen geschreven
Cal Poly, Team 16-3, Maness Spring 2010 Lid van Cal Poly, Team 16-3, Maness Spring 2010
CPSU-MANESS-S10S16G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,798
