Ga door naar hoofdinhoud
Sony Vaio PCG-981L Battery Replacement
  1. Sony Vaio PCG-981L Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before starting, be sure the device is turned off and disconnected from any power cords.
    • Place the device on a flat surface.
  2. Sony Vaio PCG-981L Battery Replacement: stap 2, afbeelding 1 van 1
    • Rotate the device 90° counterclockwise until the battery cover is in front of you.
    • The battery cover is located in the lower right side of the device in this new orientation.
  3. Sony Vaio PCG-981L Battery Replacement: stap 3, afbeelding 1 van 1
    • Flip the laptop over so that the bottom is facing up but the battery cover is still facing you.
    • In this new orientation, the battery cover is located on the left side.
  4. Sony Vaio PCG-981L Battery Replacement: stap 4, afbeelding 1 van 1
    • To remove the battery cover, use your hands to slide it upwards.
  5. Sony Vaio PCG-981L Battery Replacement: stap 5, afbeelding 1 van 3 Sony Vaio PCG-981L Battery Replacement: stap 5, afbeelding 2 van 3 Sony Vaio PCG-981L Battery Replacement: stap 5, afbeelding 3 van 3
    • Once lifted, the battery cover should flip open.
    • Now, carefully remove the battery from the device.
  6. Sony Vaio PCG-981L Battery Replacement: stap 6, afbeelding 1 van 2 Sony Vaio PCG-981L Battery Replacement: stap 6, afbeelding 2 van 2
    • Now, the battery should be completely removed from the device.
    • Be sure to dispose of the old battery properly and then you are finished.
Conclusie
Enjoy your new battery.
Gabriel Camorlinga
43 Reputatie
2 handleidingen geschreven
Cal Poly, Team 18-68, Johann Spring 2010 Lid van Cal Poly, Team 18-68, Johann Spring 2010
CPSU-JOHANN-S10S18G68
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 3,800
