Inleiding
This guide will assist with the replacement of the Sony Vaio PCG-7184L's optical drive. Please review the Troubleshooting Guide before replacing your optical drive.
Onderdelen
Geen onderdelen nodig.
  1. Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Grip the cover of the optical drive and slide it out.
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kevin McGowan
572 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-17, Regan Spring 2014 Lid van Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Leden
9 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 5
Altijd: 1,234
