Ga door naar hoofdinhoud
Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement
Wat je nodig hebt
  1. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement, Optical Drive: stap 1, afbeelding 1 van 1
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  2. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kevin McGowan
619 Reputatie
4 handleidingen geschreven
Cal Poly, Team 9-17, Regan Spring 2014 Lid van Cal Poly, Team 9-17, Regan Spring 2014
CPSU-REGAN-S14S9G17
4 Leden
18 handleidingen geschreven
Één opmerking
Has anyone found a suitable optical enclosure that would accommodate the front edge of this drive? Every enclosure I've seen so far would have the door protruding past the enclosure's opening (as opposed to sitting flush with the enclosure's opening), leaving its top edge unprotected.
Lotus Flower - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 1,748
