Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Sony Vaio PCG-6J2L Internal Fan Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-6J2L Internal Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio PCG-6J2L Internal Fan Replacement: stap 2, afbeelding 1 van 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio PCG-6J2L Internal Fan Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio PCG-6J2L Internal Fan Replacement: stap 4, afbeelding 1 van 2 Sony Vaio PCG-6J2L Internal Fan Replacement: stap 4, afbeelding 2 van 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio PCG-6J2L Internal Fan Replacement: stap 5, afbeelding 1 van 2 Sony Vaio PCG-6J2L Internal Fan Replacement: stap 5, afbeelding 2 van 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio PCG-6J2L Internal Fan Replacement, Mouse Assembly: stap 6, afbeelding 1 van 1
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio PCG-6J2L Internal Fan Replacement: stap 7, afbeelding 1 van 2 Sony Vaio PCG-6J2L Internal Fan Replacement: stap 7, afbeelding 2 van 2
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
  8. Sony Vaio PCG-6J2L Internal Fan Replacement, Speaker Assembly: stap 8, afbeelding 1 van 3 Sony Vaio PCG-6J2L Internal Fan Replacement, Speaker Assembly: stap 8, afbeelding 2 van 3 Sony Vaio PCG-6J2L Internal Fan Replacement, Speaker Assembly: stap 8, afbeelding 3 van 3
    • Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
    • To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
    • Before proceeding, remove all black tape holding down wires and other cabling.
  9. Sony Vaio PCG-6J2L Internal Fan Replacement: stap 9, afbeelding 1 van 1
    • Pop off the antenna using a pair of tweezers.
  10. Sony Vaio PCG-6J2L Internal Fan Replacement: stap 10, afbeelding 1 van 1
    • Remove the seven philips screws holding the speaker assembly in place.
    • Before removing the assembly, disconnect the ribbon cable located at the top left corner of the assembly.
    • The speaker assembly will come off with the display assembly.
  11. Sony Vaio PCG-6J2L Internal Fan Replacement, screen: stap 11, afbeelding 1 van 2 Sony Vaio PCG-6J2L Internal Fan Replacement, screen: stap 11, afbeelding 2 van 2
    • Caution: Be careful of snags when pulling up assembly and speakers.
    • To remove the VGA cable, lift up on the metal bracket and gently lift the connector off the logic board.
    • To remove the webcam cable, lift up the connector from the logic board gently.
  12. Sony Vaio PCG-6J2L Internal Fan Replacement: stap 12, afbeelding 1 van 3 Sony Vaio PCG-6J2L Internal Fan Replacement: stap 12, afbeelding 2 van 3 Sony Vaio PCG-6J2L Internal Fan Replacement: stap 12, afbeelding 3 van 3
    • Unscrew the four securing screws, two on each side of the LCD.
    • Carefully remove the LCD. The speaker, bluetooth, and webcam assembly will come up with the display assembly.
    • Caution: Be careful of snags when pulling up display and speaker assemblies.
  13. Sony Vaio PCG-6J2L Internal Fan Replacement, Internal Fan: stap 13, afbeelding 1 van 2 Sony Vaio PCG-6J2L Internal Fan Replacement, Internal Fan: stap 13, afbeelding 2 van 2
    • Remove screws from keyboard tray
    • Remove keyboard tray
  14. Sony Vaio PCG-6J2L Internal Fan Replacement: stap 14, afbeelding 1 van 1
    • Caution: When removing the fan, be careful to not tear the attached ribbon cable.
    • Unscrew all five screws from the internal fan.
    • Gently remove the internal fan.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Colin Glaves
458 Reputatie
2 handleidingen geschreven
Cal Poly, Team 25-89, Amido Spring 2010 Lid van Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Leden
63 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 10,312
