Inleiding
If your computer is not recognizing WiFi connections that it normally does, the WiFi board may be faulty and may need to be replaced. Before starting this guide, it may be helpful to have a secure place to put the screws after they have been removed.
Wat je nodig hebt
Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
Lift up the two golden knobs on the left side of the WiFi board.
Remove the single 3mm Phillips #0 screw located on the WiFi board to the top left of the battery compartment.
