Ga door naar hoofdinhoud
Sony Vaio PCG-4121GL Wifi Board Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Vaio PCG-4121GL Wifi Board Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL Wifi Board Replacement: stap 2, afbeelding 1 van 3 Sony Vaio PCG-4121GL Wifi Board Replacement: stap 2, afbeelding 2 van 3 Sony Vaio PCG-4121GL Wifi Board Replacement: stap 2, afbeelding 3 van 3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL Wifi Board Replacement: stap 3, afbeelding 1 van 1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL Wifi Board Replacement: stap 4, afbeelding 1 van 3 Sony Vaio PCG-4121GL Wifi Board Replacement: stap 4, afbeelding 2 van 3 Sony Vaio PCG-4121GL Wifi Board Replacement: stap 4, afbeelding 3 van 3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: stap 5, afbeelding 1 van 2 Sony Vaio PCG-4121GL Wifi Board Replacement, WiFi Board: stap 5, afbeelding 2 van 2
    • Lift up the two golden knobs on the left side of the WiFi board.
    • Remove the single 3mm Phillips #0 screw located on the WiFi board to the top left of the battery compartment.
  6. Sony Vaio PCG-4121GL Wifi Board Replacement: stap 6, afbeelding 1 van 2 Sony Vaio PCG-4121GL Wifi Board Replacement: stap 6, afbeelding 2 van 2
    • Once the screw and the golden knobs have been disconnected, pull the WiFi board out to the left.
    • Once the WiFi board is free from the device, remove completely.
Conclusie
Miguel Camarena
367 Reputatie
3 handleidingen geschreven
Cal Poly, Team S2-G2, White Winter 2019 Lid van Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 583
