Ga door naar hoofdinhoud
Sony Vaio PCG-4121GL SD Card Board Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-4121GL SD Card Board Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Vaio PCG-4121GL SD Card Board Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the two 3mm Phillips #0 screws on the bottom of the computer that secure the plastic backing.
  2. Sony Vaio PCG-4121GL SD Card Board Replacement: stap 2, afbeelding 1 van 3 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 2, afbeelding 2 van 3 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 2, afbeelding 3 van 3
    • Pull the bottom plate towards yourself until it unhinges fully.
    • Once the plate is free from the backing remove it completely.
  3. Sony Vaio PCG-4121GL SD Card Board Replacement: stap 3, afbeelding 1 van 1
    • Look for the blue tab that is located to the bottom left of the battery.
  4. Sony Vaio PCG-4121GL SD Card Board Replacement: stap 4, afbeelding 1 van 3 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 4, afbeelding 2 van 3 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 4, afbeelding 3 van 3
    • Pull the blue tab towards yourself until you hear a click.
    • Once the blue tab is released, pull up on the battery.
    • Once the battery can move freely, take it out completely.
    • It may be helpful to have a spudger to make it easier to release the blue tab.
  5. Sony Vaio PCG-4121GL SD Card Board Replacement, SD Card Board: stap 5, afbeelding 1 van 2 Sony Vaio PCG-4121GL SD Card Board Replacement, SD Card Board: stap 5, afbeelding 2 van 2
    • Remove seven 3mm Phillips #0 screws from the bottom of the computer.
    • Remove eight 5mm Phillips #0 screws.
  6. Sony Vaio PCG-4121GL SD Card Board Replacement: stap 6, afbeelding 1 van 3 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 6, afbeelding 2 van 3 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 6, afbeelding 3 van 3
    • Carefully remove the disk drive from its compartment.
  7. Sony Vaio PCG-4121GL SD Card Board Replacement: stap 7, afbeelding 1 van 2 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 7, afbeelding 2 van 2
    • Remove the three 2mm Phillips #00 screws located on the top right edge.
  8. Sony Vaio PCG-4121GL SD Card Board Replacement: stap 8, afbeelding 1 van 2 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 8, afbeelding 2 van 2
    • Gently pull apart the top and bottom plastic bodies.
    • Carefully remove the cable connectors.
    • Slowly detach bottom component to avoid tearing wires/connectors.
  9. Sony Vaio PCG-4121GL SD Card Board Replacement: stap 9, afbeelding 1 van 3 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 9, afbeelding 2 van 3 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 9, afbeelding 3 van 3
    • Pull apart your device and set aside the screen of your laptop.
    • Locate the SD Card Board in the bottom left of the computer body.
  10. Sony Vaio PCG-4121GL SD Card Board Replacement: stap 10, afbeelding 1 van 2 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 10, afbeelding 2 van 2
    • Remove the cables from their connectors.
    • Do not apply too much force to the cable connectors or they may tear.
  11. Sony Vaio PCG-4121GL SD Card Board Replacement: stap 11, afbeelding 1 van 2 Sony Vaio PCG-4121GL SD Card Board Replacement: stap 11, afbeelding 2 van 2
    • Lightly press down on the bottom left corner of the plastic frame.
    • Pull SD Board out towards you once it feels loose.
    • Once the SD Board is free from the plastic, remove completely
    • The SD Card slot is shown.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bryce McNeil
391 Reputatie
1 Handleiding geschreven
Cal Poly, Team S2-G2, White Winter 2019 Lid van Cal Poly, Team S2-G2, White Winter 2019
CPSU-WHITE-W19S2G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 31
Altijd: 887
