Ga door naar hoofdinhoud
Sony Vaio PCG-3C2L Hard Drive Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-3C2L Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L Hard Drive Replacement: stap 2, afbeelding 1 van 2 Sony Vaio PCG-3C2L Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L Hard Drive Replacement: stap 4, afbeelding 1 van 3 Sony Vaio PCG-3C2L Hard Drive Replacement: stap 4, afbeelding 2 van 3 Sony Vaio PCG-3C2L Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L Hard Drive Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Place the laptop so that the bottom is facing up.
  6. Sony Vaio PCG-3C2L Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  7. Sony Vaio PCG-3C2L Hard Drive Replacement: stap 7, afbeelding 1 van 2 Sony Vaio PCG-3C2L Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  8. Sony Vaio PCG-3C2L Hard Drive Replacement: stap 8, afbeelding 1 van 3 Sony Vaio PCG-3C2L Hard Drive Replacement: stap 8, afbeelding 2 van 3 Sony Vaio PCG-3C2L Hard Drive Replacement: stap 8, afbeelding 3 van 3
    • Remove the hard drive by carefully sliding it out.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 714
