Ga door naar hoofdinhoud
Sony Vaio PCG-3C2L CPU Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-3C2L CPU Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L CPU Replacement: stap 2, afbeelding 1 van 2 Sony Vaio PCG-3C2L CPU Replacement: stap 2, afbeelding 2 van 2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L CPU Replacement: stap 3, afbeelding 1 van 1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L CPU Replacement: stap 4, afbeelding 1 van 3 Sony Vaio PCG-3C2L CPU Replacement: stap 4, afbeelding 2 van 3 Sony Vaio PCG-3C2L CPU Replacement: stap 4, afbeelding 3 van 3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L CPU Replacement, Hard Drive: stap 5, afbeelding 1 van 1
    • Place the laptop so that the bottom is facing up.
  6. Sony Vaio PCG-3C2L CPU Replacement: stap 6, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  7. Sony Vaio PCG-3C2L CPU Replacement: stap 7, afbeelding 1 van 2 Sony Vaio PCG-3C2L CPU Replacement: stap 7, afbeelding 2 van 2
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  8. Sony Vaio PCG-3C2L CPU Replacement: stap 8, afbeelding 1 van 3 Sony Vaio PCG-3C2L CPU Replacement: stap 8, afbeelding 2 van 3 Sony Vaio PCG-3C2L CPU Replacement: stap 8, afbeelding 3 van 3
    • Remove the hard drive by carefully sliding it out.
  9. Sony Vaio PCG-3C2L CPU Replacement, Fan: stap 9, afbeelding 1 van 1
    • Remove the six 8 mm edge screws from the back panel using a Phillips #0 screwdriver.
    • Remove the two 8 mm corner screws from the back panel using a Phillips #0 screwdriver.
    • Remove the four 8 mm middle screws from the back panel using a Phillips #0 screwdriver.
    • Remove the three 2 mm screws from the back panel using a Phillips #0 screwdriver.
  10. Sony Vaio PCG-3C2L CPU Replacement: stap 10, afbeelding 1 van 1
    • Remove the 6 mm screw from the battery holder using a Phillips #0 screwdriver.
    • Remove the two 4 mm screws from the battery holder using a Phillips #0 screwdriver.
  11. Sony Vaio PCG-3C2L CPU Replacement: stap 11, afbeelding 1 van 3 Sony Vaio PCG-3C2L CPU Replacement: stap 11, afbeelding 2 van 3 Sony Vaio PCG-3C2L CPU Replacement: stap 11, afbeelding 3 van 3
    • Remove the CD cartridge from the back panel by sliding it out.
  12. Sony Vaio PCG-3C2L CPU Replacement: stap 12, afbeelding 1 van 3 Sony Vaio PCG-3C2L CPU Replacement: stap 12, afbeelding 2 van 3 Sony Vaio PCG-3C2L CPU Replacement: stap 12, afbeelding 3 van 3
    • Using your hands, pull up the back panel about two inches up from the rest of the laptop.
    • Disconnect the black wire connector.
    • Remove back panel.
    • Pull up the back panel slowly so the black wire connector does not break.
  13. Sony Vaio PCG-3C2L CPU Replacement: stap 13, afbeelding 1 van 2 Sony Vaio PCG-3C2L CPU Replacement: stap 13, afbeelding 2 van 2
    • Unscrew the four 4 mm captive screws from the fan casing using a Phillips #0 screwdriver.
    • Disconnect the black/red/yellow wire connector by gently pulling on the wire.
    • Remove the copper colored fan casing that contains the fan by pulling it off of the bottom of the laptop.
  14. Sony Vaio PCG-3C2L CPU Replacement: stap 14, afbeelding 1 van 1
    • Remove the three 3 mm fan casing screws from the fan casing using a Phillips #0 screwdriver.
  15. Sony Vaio PCG-3C2L CPU Replacement: stap 15, afbeelding 1 van 2 Sony Vaio PCG-3C2L CPU Replacement: stap 15, afbeelding 2 van 2
    • Remove the fan from the fan casing by sliding it out.
  16. Sony Vaio PCG-3C2L CPU Replacement, CPU: stap 16, afbeelding 1 van 2 Sony Vaio PCG-3C2L CPU Replacement, CPU: stap 16, afbeelding 2 van 2
    • Place the flathead screwdriver onto the single screw of the CPU.
    • Upon pressing the flathead onto the screw, a small pop sound will commence.
    • Step 14 and 15 do not need to be followed if you are replacing the CPU.
  17. Sony Vaio PCG-3C2L CPU Replacement: stap 17, afbeelding 1 van 2 Sony Vaio PCG-3C2L CPU Replacement: stap 17, afbeelding 2 van 2
    • Upon hearing a pop sound, the CPU can be carefully pulled out.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 1,615
