Ga door naar hoofdinhoud
Sony Vaio PCG-31311L Motherboard Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: stap 1, afbeelding 1 van 2 Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: stap 1, afbeelding 2 van 2
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew
    • These screws do not detach from the bottom plate.
  2. Sony Vaio PCG-31311L Motherboard Replacement: stap 2, afbeelding 1 van 2 Sony Vaio PCG-31311L Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to pry up on the plate and remove from device.
  3. Sony Vaio PCG-31311L Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Locate screw labeled "KB" and remove.
  4. Sony Vaio PCG-31311L Motherboard Replacement: stap 4, afbeelding 1 van 3 Sony Vaio PCG-31311L Motherboard Replacement: stap 4, afbeelding 2 van 3 Sony Vaio PCG-31311L Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool tool to pry around the edge of the keyboard.
  5. Sony Vaio PCG-31311L Motherboard Replacement: stap 5, afbeelding 1 van 3 Sony Vaio PCG-31311L Motherboard Replacement: stap 5, afbeelding 2 van 3 Sony Vaio PCG-31311L Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
    • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
    • Once the ribbon cable has been detached, lift the keyboard away from the device.
  6. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
    • Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
  7. Sony Vaio PCG-31311L Motherboard Replacement: stap 7, afbeelding 1 van 2 Sony Vaio PCG-31311L Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Locate the LCD ribbon cable
    • Pull up and away from device to detach the LCD ribbon cable.
  8. Sony Vaio PCG-31311L Motherboard Replacement: stap 8, afbeelding 1 van 3 Sony Vaio PCG-31311L Motherboard Replacement: stap 8, afbeelding 2 van 3 Sony Vaio PCG-31311L Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Close and flip over laptop.
    • Locate the WiFi network card.
    • Use the plastic opening tool to pry up the two connectors.
  9. Sony Vaio PCG-31311L Motherboard Replacement: stap 9, afbeelding 1 van 2 Sony Vaio PCG-31311L Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Locate the 6 screws on the bottom and remove.
    • Remove the final screw in the center to release the motherboard from the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tyler
45 Reputatie
5 handleidingen geschreven
USF Tampa, Team 1-1, Lacy Fall 2016 Lid van USF Tampa, Team 1-1, Lacy Fall 2016
USFT-LACY-F16S1G1
5 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 17
Altijd: 1,561
