Ga door naar hoofdinhoud
Sony Vaio PCG-161L Speakers Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-161L Speakers Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Speakers Replacement: stap 2, afbeelding 1 van 2 Sony Vaio PCG-161L Speakers Replacement: stap 2, afbeelding 2 van 2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Speakers Replacement: stap 3, afbeelding 1 van 2 Sony Vaio PCG-161L Speakers Replacement: stap 3, afbeelding 2 van 2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Speakers Replacement, Speakers: stap 4, afbeelding 1 van 1
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove the 6 mm Phillips #0 screw on the left side of the battery that holds the casing to the device.
  6. Sony Vaio PCG-161L Speakers Replacement: stap 6, afbeelding 1 van 1
    • Turn the device upside down and remove the 6 mm Phillips #0 screw holding the casing to the device.
  7. Sony Vaio PCG-161L Speakers Replacement: stap 7, afbeelding 1 van 1
    • Remove the top casing by lifting up on the plastic exposing the two speakers.
  8. Sony Vaio PCG-161L Speakers Replacement: stap 8, afbeelding 1 van 1
    • Remove the two 4 mm screws attaching the broken speaker to the casing.
    • Each speaker has two 4mm screws holding it to the casing. If you are removing both speakers, remove all four screws.
  9. Sony Vaio PCG-161L Speakers Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the wire from the board by pulling the wire out of the harness.
    • These harnesses do not have any clips or tabs. Simply pull on the wire and it will come out of the harness.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Roman Alshehri
407 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G2, Botvin Spring 2017 Lid van UMass Dartmouth, Team S3-G2, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G2
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 296
