Ga door naar hoofdinhoud
Sony Vaio PCG-161L Hard Drive Replacement
Wat je nodig hebt
  1. Sony Vaio PCG-161L Hard Drive Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Hard Drive Replacement: stap 2, afbeelding 1 van 2 Sony Vaio PCG-161L Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Hard Drive Replacement: stap 3, afbeelding 1 van 2 Sony Vaio PCG-161L Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the 6 mm screw on the left side of the battery that holds the casing to the device using a phillips head screwdriver.
  6. Sony Vaio PCG-161L Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Turn the device upside down and remove the other 6 mm screw holding the casing to the device using a phillips head screwdriver.
  7. Sony Vaio PCG-161L Hard Drive Replacement: stap 7, afbeelding 1 van 2 Sony Vaio PCG-161L Hard Drive Replacement: stap 7, afbeelding 2 van 2
    • Remove the top casing by lifting up on the plastic.
    • There are no longer any wires connecting the casing to the motherboard. The casing can be fully removed and put to the side.
  8. Sony Vaio PCG-161L Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • The ribbon cable covering the hard drive and connecting to the motherboard is held in using zero insertion force (ZIF) connector.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps, then pull the ribbon cable out.
  9. Sony Vaio PCG-161L Hard Drive Replacement: stap 9, afbeelding 1 van 1
    • Remove the four 5 mm screws holding the hard drive to the motherboard.
  10. Sony Vaio PCG-161L Hard Drive Replacement: stap 10, afbeelding 1 van 1
    • Remove the ribbon cable connecting the motherboard to the hard drive by pulling the female connector off of the pins attached the hard drive.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Roman Alshehri
407 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S3-G2, Botvin Spring 2017 Lid van UMass Dartmouth, Team S3-G2, Botvin Spring 2017
UMASSD-BOTVIN-S17S3G2
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 996
