Ga door naar hoofdinhoud
Sony Vaio Fit SVF15N26CXB Fan Replacement
Wat je nodig hebt
  1. Sony Vaio Fit SVF15N26CXB Fan Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Vaio Fit SVF15N26CXB Fan Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Fan Replacement: stap 2, afbeelding 1 van 2 Sony Vaio Fit SVF15N26CXB Fan Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Fan Replacement: stap 3, afbeelding 1 van 3 Sony Vaio Fit SVF15N26CXB Fan Replacement: stap 3, afbeelding 2 van 3 Sony Vaio Fit SVF15N26CXB Fan Replacement: stap 3, afbeelding 3 van 3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Fan Replacement: stap 4, afbeelding 1 van 1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Fan Replacement, Fan: stap 5, afbeelding 1 van 3 Sony Vaio Fit SVF15N26CXB Fan Replacement, Fan: stap 5, afbeelding 2 van 3 Sony Vaio Fit SVF15N26CXB Fan Replacement, Fan: stap 5, afbeelding 3 van 3
    • Remove the four 4.58mm Phillips #00 screws from the cooling system.
    • Unscrew the five Phillips #00 screws from the heatsink.
    • These screws will remain attached to the heatsink.
  6. Sony Vaio Fit SVF15N26CXB Fan Replacement: stap 6, afbeelding 1 van 2 Sony Vaio Fit SVF15N26CXB Fan Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the fan from the motherboard.
    • This connector should be pulled upwards, not outwards.
    • Remove the fan unit.
Conclusie
Althea McDavid
857 Reputatie
6 handleidingen geschreven
USF Tampa, Team S2-G4, Nance Spring 2018 Lid van USF Tampa, Team S2-G4, Nance Spring 2018
USFT-NANCE-S18S2G4
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 17
Altijd: 752
