Inleiding
Unlike many other laptops, the Sony Vaio Fit SVF15N26CXB has its battery within the laptop and thus is not as easy to remove as pulling it out of the back of the computer. This guide will show you how to properly remove the battery. Be sure to use the static wrist strap (shown in the guide) as a precautionary measure and recycle the battery. Also, use the magnetic project mat to keep your screws organized.
Wat je nodig hebt
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
4 andere personen hebben deze handleiding voltooid.
