Inleiding
The Sony Vaio Fit SVF15N26CXB has a flip screen that makes it different from a regular screen to remove. This guide will show you the necessary steps to take to replace the display. Use the project mat to keep the screws organized.
Wat je nodig hebt
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
Open the laptop and rotate the screen to the back side.
Remove the eight 2.85mm Phillips #00 screws from the back of the screen.
3 andere personen hebben deze handleiding voltooid.
