Ga door naar hoofdinhoud
Sony Vaio Fit 13A Wireless Card Replacement
Wat je nodig hebt
  1. Sony Vaio Fit 13A Wireless Card Replacement, Back Cover: stap 1, afbeelding 1 van 2 Sony Vaio Fit 13A Wireless Card Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Wireless Card Replacement: stap 2, afbeelding 1 van 2 Sony Vaio Fit 13A Wireless Card Replacement: stap 2, afbeelding 2 van 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Wireless Card Replacement: stap 3, afbeelding 1 van 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: stap 4, afbeelding 1 van 3 Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: stap 4, afbeelding 2 van 3 Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: stap 4, afbeelding 3 van 3
    • Use a pair of tweezers to gently disconnect the two antenna cables.
  5. Sony Vaio Fit 13A Wireless Card Replacement: stap 5, afbeelding 1 van 2 Sony Vaio Fit 13A Wireless Card Replacement: stap 5, afbeelding 2 van 2
    • Locate and remove the single 1mm Phillips #0 screw that is securing the wireless card to the motherboard.
  6. Sony Vaio Fit 13A Wireless Card Replacement: stap 6, afbeelding 1 van 2 Sony Vaio Fit 13A Wireless Card Replacement: stap 6, afbeelding 2 van 2
    • Gently grasp wireless card with two fingers and pull away from motherboard to the left.
    • Do not pull the wireless card up when removing it. This could snap the connections.
Conclusie
Alex Prange
527 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-19, Maness Winter 2015 Lid van Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 1,823
