Ga door naar hoofdinhoud
Sony Vaio Fit 13A Battery Replacement
Wat je nodig hebt
  1. Sony Vaio Fit 13A Battery Replacement, Back Cover: stap 1, afbeelding 1 van 2 Sony Vaio Fit 13A Battery Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Battery Replacement: stap 2, afbeelding 1 van 2 Sony Vaio Fit 13A Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Battery Replacement: stap 3, afbeelding 1 van 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Battery Replacement, Battery: stap 4, afbeelding 1 van 2 Sony Vaio Fit 13A Battery Replacement, Battery: stap 4, afbeelding 2 van 2
    • Locate and remove the ten 1mm Phillips #0 screws that are securing the battery in place.
  5. Sony Vaio Fit 13A Battery Replacement: stap 5, afbeelding 1 van 2 Sony Vaio Fit 13A Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery with the Plastic Opening Tool by placing the tool between the battery and the computer and cautiously prying it out.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Alex Prange
527 Reputatie
3 handleidingen geschreven
Cal Poly, Team 21-19, Maness Winter 2015 Lid van Cal Poly, Team 21-19, Maness Winter 2015
CPSU-MANESS-W15S21G19
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 7,938
