Inleiding
A dirty filter can cause your projector to overheat and malfunction. A clean filter will prolong the life of your projector and keep it running smoothly. Cleaning this filter also allows your image projected on the screen to look significantly better and clearer providing a better experience for the user.
You should clean your Sony Sony VPL-HW55ES-SXRD projector filter every 200 hours of use, or at least once a month. The projector will even pop up with a red text on the bottom right hand of the screen letting you know it needs to be cleaned. With this step-by-step guide, you will be able to replace or clean your Sony VPL-HW55ES-SXRD filter within minutes.
Wat je nodig hebt
Hopefully, this guide has shown you how to replace or clean your filter within a very short amount of time. Make sure to do this at least once a month and your projector will be very happy!
