Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Power down the laptop by pressing the power button.
Turn the laptop onto its backside.
To release the battery, hold both the release button and the unlock button at the same time.
Remove the battery out from the notch while continuing to hold the release button.
Remove the one screw with a Phillips #00 screwdriver.
Pull the two retaining arms away from the center of the RAM chip.
The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
Pull the RAM stick out of its socket.
To remove the second stick of RAM, repeat steps six and seven.
When installing RAM, make sure sticks are firmly in place or the computer will not register them.
Één andere persoon heeft deze handleiding voltooid.
