Ga door naar hoofdinhoud
Inleiding
This guide will inform readers on how to safely uninstall the battery of the Sony VAIO VPC-EB33FM laptop.
Gereedschap
Geen gereedschap opgegeven.
Onderdelen
  1. If the laptop isn't turned off, then do so by holding down the power button. Turn the laptop onto its backside.
    • If the laptop isn't turned off, then do so by holding down the power button.
    • Turn the laptop onto its backside.
  2. Locate the battery below the screen attachment.
    • Locate the battery below the screen attachment.
    • The battery is shaped as a long rectangle with rounded edges.
  3. Press into the release button while holding the unlock button in position.
    • Press into the release button while holding the unlock button in position.
  4. Lift the battery out at the notch while holding the release button. Lift the battery out at the notch while holding the release button.
    • Lift the battery out at the notch while holding the release button.
Conclusie
Kevin
511 Reputatie
3 handleidingen geschreven
Cal Poly, Team 18-39, Regan Winter 2013 Lid van Cal Poly, Team 18-39, Regan Winter 2013
CPSU-REGAN-W13S18G39
5 Leden
9 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,354
