Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Loosen 2 latches holding the keyboard down with the flat tip screwdriver, one by the F5 key, and the other by the Num Lock key. Move keyboard towards the touch pad and pull up.
Remove the ribbon carefully.
I added this step separate for the ones that just want to upgrade the RAM.
Remove one screw from top and one from under cap opposite of the power button.
Unsnap the top cover carefully around the edges.
Disconnect 3 ribbons and pull top carefully towards the left side. Remove ribbon from the motherboard.
Remove the RAM.
Remove the hard drive metal bracket. Mine had 2 screws but I believe there are supposed to be 4 (lost them when I replaced the hard rive last time). Disconnect ribbon from motherboard.
Remove the wireless card. There are 2 antennas connected to it, the back wire goes on the main, gray on aux.
Remove one screw form the sound card. Disconnect one ribbon and one connector (under) from card.
Remove the DVD drive by unscrewing 5 screws, make sure to open the drive with the paper clip to access the last one.
Remove one screw from the network/modem combo card. Disconnect 3 connectors and one ribbon from cards. There is an additional connector on the motherboard.
Time to remove the screen. Remove 2 screws holding the hinges down
Remove ground screw and wire.
Remove 4 bezel screw covers. Remove 4 screws.
Remove 2 caps from hinges. Remove bezel.
Remove 4 screws holding screen. Disconnect one connector from the power module
At last, the motherboard. Remove 2 screws holding a plastic bracket down.
Disconnect the ribbon connector and remove 3 screws.
All done! Sorry for the crappy picture.
Just in case you are wondering, is back together and working like a champ.
3 opmerkingen
thank you for sharing your knowledge, even with "fuzzy pictures" I found this to be very helpful and useful ... I look forward to reading more of your material ... Jim 8)
thank you for sharing your knowledge, even with the "fuzzy" pictures I found this article/repair Manuel to be very useful and helpful ... once again, thank you ...
just a note to some that might find using a very small pair of needle nose pliers with serrated teeth for replacing the tiny pieces of plastic that secures the ribbons in place ... I have a pair, but they are just a bit too big and I need to find a source for some really small serrated tip pliers, so if anyone can direct me to a source, this would be most helpful and appreciated ... thanks, Jim
