Ga door naar hoofdinhoud
Sony VAIO VGN-FW 590 Keyboard Key Replacement
Wat je nodig hebt
  1. Sony VAIO VGN-FW 590 Keyboard Key Replacement, Keyboard Key: stap 1, afbeelding 1 van 1
    • Open your computer.
    • Make sure the computer is turned off.
  2. Sony VAIO VGN-FW 590 Keyboard Key Replacement: stap 2, afbeelding 1 van 1
    • Find the broken key.
    • The S key is our example though it is not broken.
  3. Sony VAIO VGN-FW 590 Keyboard Key Replacement: stap 3, afbeelding 1 van 2 Sony VAIO VGN-FW 590 Keyboard Key Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic spudger underneath the edge of the key.
    • Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
  4. Sony VAIO VGN-FW 590 Keyboard Key Replacement: stap 4, afbeelding 1 van 1
    • Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
    • Press the replacement key firmly in the center until it is completely depressed and attached to the key base.
  5. Sony VAIO VGN-FW 590 Keyboard Key Replacement: stap 5, afbeelding 1 van 1
    • Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
Conclusie
Congratulations! You have successfully replaced a key on your keyboard.
Jennifer Pache
304 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 1,493
