Ga door naar hoofdinhoud
Sony VAIO VGN-FW 590 Battery Replacement
Wat je nodig hebt
  1. Sony VAIO VGN-FW 590 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Sony VAIO VGN-FW 590 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Battery Replacement: stap 2, afbeelding 1 van 2 Sony VAIO VGN-FW 590 Battery Replacement: stap 2, afbeelding 2 van 2
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Battery Replacement: stap 3, afbeelding 1 van 2 Sony VAIO VGN-FW 590 Battery Replacement: stap 3, afbeelding 2 van 2
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
Conclusie
Morton Wakeland
101 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 20
Altijd: 812
