Ga door naar hoofdinhoud
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
Wat je nodig hebt
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: stap 1, afbeelding 1 van 1
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
    If a hard drive is installed it has to be removed to complete the next step. There are also two screws (one on each side) of the battery connector that have to be removed.
    Daniel - Antwoord
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 5, afbeelding 1 van 2 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 5, afbeelding 2 van 2
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
Conclusie
Alex Pham
207 Reputatie
1 Handleiding geschreven
2 opmerkingen
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - Antwoord
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 2,422
