Ga door naar hoofdinhoud
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
Wat je nodig hebt
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: stap 1, afbeelding 1 van 1
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 5, afbeelding 1 van 2 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: stap 5, afbeelding 2 van 2
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
Conclusie
Alex Pham
207 Reputatie
1 Handleiding geschreven
2 opmerkingen
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - Antwoord
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 15
Altijd: 2,489
