Ga door naar hoofdinhoud
Sony VAIO PCG-F360 Speaker Panel Replacement
Wat je nodig hebt
  1. Sony VAIO PCG-F360 Speaker Panel Replacement, Battery: stap 1, afbeelding 1 van 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Speaker Panel Replacement: stap 2, afbeelding 1 van 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Speaker Panel Replacement: stap 3, afbeelding 1 van 1
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Speaker Panel Replacement: stap 4, afbeelding 1 van 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: stap 5, afbeelding 1 van 3 Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: stap 5, afbeelding 2 van 3 Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: stap 5, afbeelding 3 van 3
    • There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony VAIO PCG-F360 Speaker Panel Replacement: stap 6, afbeelding 1 van 3 Sony VAIO PCG-F360 Speaker Panel Replacement: stap 6, afbeelding 2 van 3 Sony VAIO PCG-F360 Speaker Panel Replacement: stap 6, afbeelding 3 van 3
    • Push the beige tab in the direction of the ribbon. it should only move a small amount
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
Conclusie
Hannah Millea
401 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 3-5, Calaway Spring 2014 Lid van UMass Dartmouth, Team 3-5, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G5
2 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 182
