Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Position the laptop screen-side down as shown.
In this position the battery housing will be located on the right hand side.
Lift the panel up and then out to gain access to the battery.
The battery is now removed and it is safe to move on to uninstalling other components.
Use the pludger to pop off the key by prying under it.
You now can clean and replace the key.
