Inleiding
This repair guide shows how to replace and clean out the fan.
Wat je nodig hebt
Turn the laptop upside down so that the top is sitting on a flat surface.
If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
Remove the four 4mm Phillips screws around the hard drive.
Carefully lift the hard drive cage out.
Carefully disconnect the copper strip to pull out the hard drive.
Één andere persoon heeft deze handleiding voltooid.
