Ga door naar hoofdinhoud
Sony VAIO VPCEE26FX Keyboard Replacement
Wat je nodig hebt
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: stap 1, afbeelding 1 van 2 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: stap 2, afbeelding 1 van 2 Sony VAIO VPCEE26FX Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 2 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: stap 3, afbeelding 2 van 2
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: stap 5, afbeelding 1 van 2 Sony VAIO VPCEE26FX Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: stap 6, afbeelding 1 van 2 Sony VAIO VPCEE26FX Keyboard Replacement: stap 6, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: stap 7, afbeelding 1 van 1
  8. Sony VAIO VPCEE26FX Keyboard Replacement: stap 8, afbeelding 1 van 1
    • Lift the keyboard up and away from the computer.
Conclusie
Christopher Hover
679 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 Lid van UMass Dartmouth, Team S2-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S2G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 19
Altijd: 1,170
