Ga door naar hoofdinhoud
Sony VAIO VPCEE26FX Hard Disk Drive Replacement
Wat je nodig hebt
  1. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Hard Disk Drive Replacement: stap 2, afbeelding 1 van 2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement: stap 2, afbeelding 2 van 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: stap 3, afbeelding 1 van 2 Sony VAIO VPCEE26FX Hard Disk Drive Replacement, Hard Disk Drive: stap 3, afbeelding 2 van 2
    • Using a JIS #0 screwdriver, remove the two 4mm screws securing the hard drive cover to the laptop.
    • Lift the hard drive up and out of its place.
    • The drive cover and hard drive are not pictured. They are both missing from this particular device.
Conclusie
Christopher Hover
679 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 Lid van UMass Dartmouth, Team S2-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S2G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 1,723
