Ga door naar hoofdinhoud
Sony UBP-UX80 Button PCB Replacement
Wat je nodig hebt
  1. Sony UBP-UX80 Button PCB Replacement, Top Cover: stap 1, afbeelding 1 van 3 Sony UBP-UX80 Button PCB Replacement, Top Cover: stap 1, afbeelding 2 van 3 Sony UBP-UX80 Button PCB Replacement, Top Cover: stap 1, afbeelding 3 van 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Button PCB Replacement: stap 2, afbeelding 1 van 3 Sony UBP-UX80 Button PCB Replacement: stap 2, afbeelding 2 van 3 Sony UBP-UX80 Button PCB Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Button PCB Replacement: stap 3, afbeelding 1 van 2 Sony UBP-UX80 Button PCB Replacement: stap 3, afbeelding 2 van 2
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Button PCB Replacement: stap 4, afbeelding 1 van 3 Sony UBP-UX80 Button PCB Replacement: stap 4, afbeelding 2 van 3 Sony UBP-UX80 Button PCB Replacement: stap 4, afbeelding 3 van 3
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Button PCB Replacement, Front Cover: stap 5, afbeelding 1 van 3 Sony UBP-UX80 Button PCB Replacement, Front Cover: stap 5, afbeelding 2 van 3 Sony UBP-UX80 Button PCB Replacement, Front Cover: stap 5, afbeelding 3 van 3
    • Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
    • Pull directly up on the ribbon cable to disconnect it from the motherboard
    • Gently pull the cable back away from the motherboard pulling the tape off with it
  6. Sony UBP-UX80 Button PCB Replacement: stap 6, afbeelding 1 van 1
    • Once all pieces of tape have been pulled up, the ribbon cable should look like this.
  7. Sony UBP-UX80 Button PCB Replacement: stap 7, afbeelding 1 van 2 Sony UBP-UX80 Button PCB Replacement: stap 7, afbeelding 2 van 2
    • There are screws on every side of the front panel holding it in. Use a #2 Phillips head screwdriver to remove the nine screws.
    • Unscrew the three 10.5 mm long ph #2 screws on the top.
    • Unscrew the four 10.5 mm long ph #2 screws on the bottom.
  8. Sony UBP-UX80 Button PCB Replacement: stap 8, afbeelding 1 van 2 Sony UBP-UX80 Button PCB Replacement: stap 8, afbeelding 2 van 2
    • Use a Phillips #2 screwdriver to remove the 10.5 mm screws, one on each side of the device.
  9. Sony UBP-UX80 Button PCB Replacement: stap 9, afbeelding 1 van 3 Sony UBP-UX80 Button PCB Replacement: stap 9, afbeelding 2 van 3 Sony UBP-UX80 Button PCB Replacement: stap 9, afbeelding 3 van 3
    • Lift tab on the left side of the device
    • Work your way right, lifting the next tabs. One on the bottom and one the Top
    • Continue working the tabs on the top and bottom, keeping them from snapping back in place.
  10. Sony UBP-UX80 Button PCB Replacement: stap 10, afbeelding 1 van 1
    • Once all tabs are disconnected, pull the front panel forward to fully disconnect it
  11. Sony UBP-UX80 Button PCB Replacement, Button PCB: stap 11, afbeelding 1 van 1
    • Once the Front Panel is removed, look to the inside of it and find a green circuit board which will be the Personal Control Board (PCB).
  12. Sony UBP-UX80 Button PCB Replacement: stap 12, afbeelding 1 van 1
    • Remove the four 10mm screws holding the PCB in place and unscrew them using the #2 Phillips head screwdriver.
  13. Sony UBP-UX80 Button PCB Replacement: stap 13, afbeelding 1 van 2 Sony UBP-UX80 Button PCB Replacement: stap 13, afbeelding 2 van 2
    • Lift up on the bottom of the silver bracket and pull out to remove the PCB.
Conclusie
To reassemble your device, follow these instructions in reverse order. Remember to not force the screw into the holes to not strip the threads.
Ryan Masoud
193 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-5, Petersen Spring 2023 Lid van UMass Dartmouth, Team 2-5, Petersen Spring 2023
UMASSD-PETERSEN-S23S2G5
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 175
