Ga door naar hoofdinhoud
Sony Tablet S Wi-Fi Antenna Replacement
Wat je nodig hebt
  1. Sony Tablet S Wi-Fi Antenna Replacement, Battery: stap 1, afbeelding 1 van 2 Sony Tablet S Wi-Fi Antenna Replacement, Battery: stap 1, afbeelding 2 van 2
    • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
    • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
  2. Sony Tablet S Wi-Fi Antenna Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 10mm Phillips #0 screws located under the grips.
  3. Sony Tablet S Wi-Fi Antenna Replacement: stap 3, afbeelding 1 van 2 Sony Tablet S Wi-Fi Antenna Replacement: stap 3, afbeelding 2 van 2
    • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
    • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
  4. Sony Tablet S Wi-Fi Antenna Replacement: stap 4, afbeelding 1 van 1
    • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
  5. Sony Tablet S Wi-Fi Antenna Replacement: stap 5, afbeelding 1 van 1
    • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
    • Use caution when removing the cable, as the socket is very fragile.
  6. Sony Tablet S Wi-Fi Antenna Replacement: stap 6, afbeelding 1 van 1
    • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
  7. Sony Tablet S Wi-Fi Antenna Replacement: stap 7, afbeelding 1 van 1
    • Slide the bottom grey cover piece away from the body and remove it.
    • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
  8. Sony Tablet S Wi-Fi Antenna Replacement: stap 8, afbeelding 1 van 1
    • Remove the five 4mm Phillips #000 screws.
    • Remove the two 5mm Phillips #000 screws holding the charger in place.
  9. Sony Tablet S Wi-Fi Antenna Replacement: stap 9, afbeelding 1 van 3 Sony Tablet S Wi-Fi Antenna Replacement: stap 9, afbeelding 2 van 3 Sony Tablet S Wi-Fi Antenna Replacement: stap 9, afbeelding 3 van 3
    • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
    • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
  10. Sony Tablet S Wi-Fi Antenna Replacement: stap 10, afbeelding 1 van 2 Sony Tablet S Wi-Fi Antenna Replacement: stap 10, afbeelding 2 van 2
    • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
  11. Sony Tablet S Wi-Fi Antenna Replacement: stap 11, afbeelding 1 van 1
    • Remove the three 5mm Phillips #0 screws securing the original battery.
  12. Sony Tablet S Wi-Fi Antenna Replacement: stap 12, afbeelding 1 van 2 Sony Tablet S Wi-Fi Antenna Replacement: stap 12, afbeelding 2 van 2
    • Use the spudger to pop the battery loose and remove the battery.
  13. Sony Tablet S Wi-Fi Antenna Replacement, Wi-Fi Antenna: stap 13, afbeelding 1 van 3 Sony Tablet S Wi-Fi Antenna Replacement, Wi-Fi Antenna: stap 13, afbeelding 2 van 3 Sony Tablet S Wi-Fi Antenna Replacement, Wi-Fi Antenna: stap 13, afbeelding 3 van 3
    • Use a spudger to carefully remove the black tape, and gently disconnect the pin connector.
  14. Sony Tablet S Wi-Fi Antenna Replacement: stap 14, afbeelding 1 van 2 Sony Tablet S Wi-Fi Antenna Replacement: stap 14, afbeelding 2 van 2
    • Remove the copper tape securing the Wi-Fi antenna.
  15. Sony Tablet S Wi-Fi Antenna Replacement: stap 15, afbeelding 1 van 1
    • Lift the entire assembly out.
Conclusie
Austin Mann
287 Reputatie
5 handleidingen geschreven
USF Tampa, Team 3-5, Passmore Fall 2016 Lid van USF Tampa, Team 3-5, Passmore Fall 2016
USFT-PASSMORE-F16S3G5
3 Leden
Één opmerking
no mention of disconnecting or re connecting the wiring that comes to the screen on removal ? great illustration though love it, cheers Don
Donald - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 490
