Inleiding
If you have a problem with starting-up the OS, or if you want to erase all data, or you forgot your password, PIN, pattern code you can do a Factory reset.
Attention!!! This will erase all your data!!! It's good to do BACKUP first.
Video overzicht
Metod 1:
- Settings
- Backup & reset
- Factory data reset
The tablet will restart automatically.
!!! From the "Backup & reset" menu you can do Back up my data !!!
Metod 2:
Power of the tablet. Pres and hold the Power On key and the Volume Up key at the same time.
When you see the Sony logo release the Power On button but continue to press the Volume Up button.
Now you are in the Android recovery menu. Use Volume keys to scroll and the Power On key to select. From the options select:
- Reset to Factory Settings
- Yes - erase all user data
- The tablet will restart alone
19 andere personen hebben deze handleiding voltooid.
23 opmerkingen
Hallo , I follow the steps , nothing is happening . Exists a different way ? dedudan@yahoo.com
hi man
i do but its very VERY specific
press power
when te white led upper power flash on quiqkly relase power and press vol up..........
when the display make a very litle flash relase the vol buton
ENJOY AND GIVE THANKS
Hi, you are my knight in shining armour. You were right, it´s incredibly specific. You have to watch the white light above the power button and be plugged in into a socket. Nobody else mentioned the little white light, I was close to believe my tablet was defect.
Thank you very, very much.
ive tried it many times but still is stuck on sony logo
