Ga door naar hoofdinhoud
Sony TCM-919 Cassette-Corder Speaker Replacement
Wat je nodig hebt
  1. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Battery Cover: stap 1, afbeelding 1 van 1
    • Turn the device around so that the back cover is facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Back Casing: stap 2, afbeelding 1 van 1
    • Remove the 5, 5.95mm screws as indicated in the picture.
  3. Sony TCM-919 Cassette-Corder Speaker Replacement, Desolder Speaker Wires: stap 3, afbeelding 1 van 2 Sony TCM-919 Cassette-Corder Speaker Replacement, Desolder Speaker Wires: stap 3, afbeelding 2 van 2
    • Look to the back of the top cover.
    • Desolder the two wires from the speaker.
  4. Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Speaker: stap 4, afbeelding 1 van 2 Sony TCM-919 Cassette-Corder Speaker Replacement, Remove Speaker: stap 4, afbeelding 2 van 2
    • Squeeze the two prongs holding the speaker in place and remove the metal piece.
    • Remove the speaker by gently lifting it up from the cover and pulling.
Conclusie
Marygayle Martin
506 Reputatie
5 handleidingen geschreven
Baylor, Team 4-3, Williams Fall 2014 Lid van Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 495
