Ga door naar hoofdinhoud
Sony TCM-919 Cassette-Corder Operating Buttons Replacement
Wat je nodig hebt
  1. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Remove Back Cover: stap 1, afbeelding 1 van 1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Back Cover Screw Removal: stap 2, afbeelding 1 van 1
    • Remove the 5 5.95mm screws as indicated in the picture with the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Locate Buttons: stap 3, afbeelding 1 van 1
    • Look to the back of the top cover and locate the broken button(s).
  4. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: stap 4, afbeelding 1 van 2 Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: stap 4, afbeelding 2 van 2
    • Use a splunger tool to undo the two clips that belong to any broken buttons.
    • Turn the device over and using your finger, push out the loose button.
Conclusie
Marygayle Martin
506 Reputatie
5 handleidingen geschreven
Baylor, Team 4-3, Williams Fall 2014 Lid van Baylor, Team 4-3, Williams Fall 2014
BU-WILLIAMS-F14S4G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 816
