Ga door naar hoofdinhoud
Sony Smart Watch SW2 Display Assembly Replacement
Wat je nodig hebt
  1. Sony Smart Watch SW2 Display Assembly Replacement, Display Assembly: stap 1, afbeelding 1 van 1
    • Detach the smart watch from the band by pushing on the back of the watch housing.
    • The power button may fall out once the smart watch is detached.
    • Set aside the power button and watch band as they are no longer needed for further disassembly.
  2. Sony Smart Watch SW2 Display Assembly Replacement: stap 2, afbeelding 1 van 1
    • Use a plastic opening tool to carefully pry the LCD screen from the watch housing.
  3. Sony Smart Watch SW2 Display Assembly Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool or spudger to lift the screen assembly press-fit connector free.
  4. Sony Smart Watch SW2 Display Assembly Replacement: stap 4, afbeelding 1 van 1
    • Set aside the detached LCD screen to access the battery.
Conclusie
To reassemble your device, follow these steps in reverse order.
3 andere personen hebben deze handleiding voltooid.
Vincent Shiue
265 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G5, Freund Spring 2018 Lid van IUPUI, Team S1-G5, Freund Spring 2018
IUPUI-FREUND-S18S1G5
3 Leden
1Gids Commentaar
whwre can I get the LCD screen for SW2?
faizal ahamed - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 17
Altijd: 3,317
