Ga door naar hoofdinhoud
Sony SRS-XE200 Motherboard Replacement
Wat je nodig hebt
  1. Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: stap 1, afbeelding 1 van 2 Sony SRS-XE200 Motherboard Replacement, Speaker Assembly: stap 1, afbeelding 2 van 2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Motherboard Replacement: stap 3, afbeelding 1 van 2 Sony SRS-XE200 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Motherboard Replacement: stap 4, afbeelding 1 van 2 Sony SRS-XE200 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 3 Sony SRS-XE200 Motherboard Replacement, Motherboard: stap 5, afbeelding 2 van 3 Sony SRS-XE200 Motherboard Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the cord connecting the charging port to the motherboard.
  7. Sony SRS-XE200 Motherboard Replacement: stap 7, afbeelding 1 van 3 Sony SRS-XE200 Motherboard Replacement: stap 7, afbeelding 2 van 3 Sony SRS-XE200 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Remove the two 0.8 mm screws attaching the motherboard to the case compartment with a Phillips #1 screwdriver.
    • Detach the motherboard from the case compartment.
Conclusie
Één opmerking
Hy please I m from morrocco i need a matherbeard a have a speaker but not work i d'not no way i need help plz
Abdou Abdou - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 25
Altijd: 332
